B16a out; Type R In
B16a out; Type R In
Ok so when I get back from Texas, I am going to order a B18C Type R spec to put into my 93 hatch. It already has a b16a in it, but the thing is since the b16 is OBD1, what would I need to do to get the Type R to run correctly, atm I have a p28 ecu that is chipped and socketed. But I know that I will need to get a right hand drive engine harness for the new motor, but will I need to get a OBD2a to OBD1 conversion harness for the ECU? Or use the OBD2 ecu that comes with the motor? And If I keep OBD1 what all would I need to do if I use the engine harness that goes with the TypeR. I don't want to use the old engine harness cause I am afraid some of the wiring maybe bad which could have led to all the dizzy problems I am having. I am sorry if this has been asked a bunch before, I just thought i'd ask myself to see what kind of answers I got.
Re: B16a out; Type R In
Why a z6 harness? I am just wondering because the motor I am ordering comes with a engine harness, but it is for the obd2. I just don't want to have to go and cut and rewire stuff on a old harness to make this work.
ur z6 harness will be plug and play... u can wire the knock sensor but shouldnt need it if ur planning on running the p28.. ull just need to reuse ur dizzy and alternator off ur b16..
Well I don't know if it is a z6 harness, I don't want to use the one I have right now cause of fear that the wiring is bad. But my hatch is RHD, I am not sure if the harness is for the b16a that is in it or for something else. The dizzy in my b16 is shot that is one of the reasons I am going to put a swap in, I am not paying $500 for a new oem dizzy from honda. The alternator should be fine. But I am going to use the p28 ecu if I can, but if I use the harness from the Type R how can I make that work with the ecu?
Check out this thread.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
It has all the answers you could need about engine swaps, and if you repost your question there you will definitely get a reply from one of the experts who watch the thread.
Also check this thread out, It covers installing a OBD2 integra engine into a OBD1 92-95 civic.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/dans-massive-obd2-b18b1-into-1992-civic-cx-hatch-write-up-2239971/
I'm confused. First: You have a RHD Civic, shouldn't the wires be plug and play with your new JDM OBD2 swap? Secondly: Blown dizzy justifies buying a new swap? Go for it.
Thank you guys for the help I really appreciate it. But no it doesn't mean that I'm going to buy a new swap cause the dizzy went out. I have always wanted to do one myself so I can learn more about the whole process. And this is my chance to do it so I'm going to take it.
yellowcanary.
03-16-2015 02:03 PM
