B16 Civic Si HELP!!!
ok guys, i just got back from crusing, i was BEATING on my car!!!!! when i got home, i shut the car off, then i started it again but this time it didnt turn on. there is no power either. it seems like the battery is dead. but my battery was fine. or is it just becuase my engine is too hott right now? my check engine light is not on. and yes i have gas in the tank, and im stepping on the clutch. help anyone?
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">look for oil leaks, chances are you threw a rod through ure block.</TD></TR></TABLE>
well its dark now, so ill check for oil leaks on teh floor. if i threw a rod through my block........why did my car ran and sounded normal while driving back home?? help?
i was messin... from youre description it is REALLY hard to pin point a problem, obviously. But worse case scenario you warped the head or something causing it to run rough.
you should never turn ure car off after going WOT for a period of time, just chilll and let it cool.
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">nevermind, youre battery conneciion came loose.. </TD></TR></TABLE>
yeah maybee beucase my positive batter wire is loose, i just remember that. and my car was bouncy alot on the way home (bad roads) it happen once before, i thought my car died. poped the hood adn it was just a loose wire. while driving home, i notice at a red light if i throw it in netrual and let off teh gas, the car lagged like it was going to shut off, so what i did to keep it on was keep revving the car so it wont die, and it helped. i also notice my headlights flickering when i let off the throttle too. what do you think?
Eklove2496
12-22-2013 03:12 PM
SkatingStoner95
23
05-11-2011 02:45 PM
nycpatron
15
05-17-2010 08:13 PM
