b16 or b18
Old 03-22-2013, 06:27 AM
  #101
wolfman93's Avatar
Default Re: b16 or b18
Listen here **** stick. All I want is someone who will tell me their opinion of these parts not your mouth.
Old 03-22-2013, 06:29 AM
  #102
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
This is not an opinion poll forum, it is a tech forum. Once again listen to the others who said to research, they have nice cars and everything has been done before.
Old 03-22-2013, 08:45 AM
  #103
Hamza_Z'sTuning's Avatar
Lol at all these kids arguing...
Old 03-22-2013, 08:51 AM
  #104
JuggerNaut-CTR's Avatar
^Look who's back...
Striving to get banned again?
Old 03-22-2013, 09:09 AM
  #105
The Grumpiest
grumblemarc's Avatar
For the 4th time?
Old 03-22-2013, 02:35 PM
  #106
Op I would go for a b20 why? Because you can just add a vtec head (b16) and tranny you will be going as fast as type r but better because its 2.0 rather than 1.8
Old 03-22-2013, 02:38 PM
  #107
The Grumpiest
And you failed to mention that B20s are not made for high revs which most of you people do as if you have a Formula 1 Engine in it.
  #108
If not the b20 I would go for a gsr no need to waste money on a b16 they are really close to d series and for that ensurance rate it is not worth it.
Old 03-22-2013, 02:40 PM
  #109
The Grumpiest
Make up your mind. All you're doing is clouding the issue. Get this. No, get that.
  #110
Insurance*
Old 03-22-2013, 02:46 PM
  #111
Op you want to go fast go with this setup: B18A1 Block
B16 Head,P30 High Compression Pistons,Shotpeened LS Rods,ARP Rod Bolts,ARP Head Studs,Exedy Stage 1 Clutch,B17 YS1 Transmission,Skunk2 Intake Manifold
310 Precision Injectors,Stock Exhaust Manifold
b17 cams thats my cousins old setup but he went hella quick in his ef hatch no one caught up.No one.
Old 03-22-2013, 02:49 PM
  #112
Master Ninja
Eddie's Avatar
No one OP no one!
Old 03-22-2013, 04:00 PM
  #113
wolfman93's Avatar
Alright thanks. I appreciate the advice and info
Old 03-22-2013, 04:09 PM
  #114
The Robot Cow's Avatar
just get a stock civic
no point of building a car just to show off around town. Yea you can have all the high end parts but take it to a track like a real man and not be a ******* idiot on the streets
Old 03-22-2013, 04:20 PM
  #115
wolfman93's Avatar
Its a daily driver but it will be at the track on weekends. But not just drag racing but time attack and road courses.
Old 03-22-2013, 07:07 PM
  #116
The stage 1 clutch, s2 intake mani, injectors and cams didnt make that setup any quicker...just so you know.
And why would you tell him to get a cable trans?
B17 and b16 share same gearing besides 1st is a tad shorter on b17, so really no real difference.
Old 03-22-2013, 07:19 PM
  #117
wolfman93's Avatar
Ok. I was planning b16 transmission and b20 vtec mildly built in my lightened dx hatch.
Old 03-22-2013, 07:21 PM
  #118
Master Ninja
Eddie's Avatar
Your not going to get anywhere with him.
Old 03-22-2013, 08:49 PM
  #119
wolfman93's Avatar
On the b17 trans wouldn't a cable to hydraulic kit work? Just asking. But I'm prolly just gonna use b16 or itr trans
Old 03-22-2013, 10:11 PM
  #120
Why would you even want to?
Not just 1 itr trans...so what one are you referring to?
Old 03-23-2013, 02:47 AM
  #121
rhymeshark916's Avatar
GSR/Type R B18C It's just that simple. HB are light and perfect for the torque. If you want to go with a B20V then sure. This thread as turned to a novel. LOL.
Old 03-23-2013, 03:32 AM
  #122
The Grumpiest
This is why you don't ask for opinions in a tech thread. Now you're all kinds of confused. Should have found some build threads and just copied one of them.
Old 03-23-2013, 05:29 AM
  #123
wolfman93's Avatar
This is the set up Im planning on.
B20B/Z Block
Darton Sleeves
ACL Bearings
K1 Billet H beam Rods
JE Pistons .040” overbore 85.0mm 12.1:1 cr
ARP Rod Bolts
Hastings Rings
Balanced & Blueprinted
Fel-Pro Gaskets
Moroso 6qt oil pan
B16A Head
Arp Head Studs
Port & polish
Crower cams #63402A-2 Stage 2 1800-9250rpm redlines 9750
Crower Cams Dual Valve Springs & Chromoly Retainers
Skunk 2 Cam Gears
Oem Valve Guides, oil pump, water pump
Skunk 2 Intake manifold
DC Sports Header Hi-Flo Cat w/ current 2.5” exhaust
Walbro 255lph fuel pump
Dsm 450cc injectors
Chipped ls ecu w/ tune
Golden Eagle vtec conversion kit
98+ ITR transmission
Exedy Flywheel and 6 puck clutch
Royal Purple Fluids
Old 03-23-2013, 05:35 AM
  #124
The Grumpiest
Can you tell me what this means?
"Balanced & Blueprinted"
Old 03-23-2013, 05:39 AM
  #125
wolfman93's Avatar
Balance the rotating assembly and blue print I forget exactly what they do but it frees up more power.I have it done on my sbcs when Im building them and it helps out a little more.
Quick Reply: b16 or b18
