Axle Problems with B16 Swap
Does anyone else have constant axle problems after a B16 Swap? I've had them replaced 2 or 3 times. These are quality axles as well. No Cheap aftermarkets. Anyone?
Re: Axle Problems with B16 Swap (ADVAN EG2)
also check your motor mounts and make sure everything is installed properly and the suspension isnt binding in any way
1 Post
what kind of caster/camber u running, along with what advan eg2 said, all of these will change the pinion angle, and will take out the axle prematurely.
Re: Axle Problems with B16 Swap (mx621)
A little off the subject, I was feeling my car pull to the left hard and occasionally to the right. Could this just be because of the road pitching from side to side. The roads in my town are fairly old and worn. I have no power steering so I guess it's a little sensitive.
Sirfallsalot243
10
12-24-2006 08:39 PM
