Auto transmission guru? Shifts hard after swap
Anyone on here know much about the auto trans? I swapped a new one in my wife's 98 CX hatch, but it shifts hard. I'm trying to figure out if there's a way to adjust it so it doesn't grab so hard.
Also, is there a factory service manual that I can download somewhere?
Re: Auto transmission guru? Shifts hard after swap
Is the D4 light blinking on the dash?
Is the CEL ON? If so, pull the CEL code. It may indicate a transmission problem.
Is the ATF low?
I PM'd you.
Is the ATF low?
I PM'd you.
my first thought would be ATF if it was replaced i really hope you filled the toqure convetrer cause that would cause hard grabbing and shifting problems
When I put everything back together I originally had a CEL, it was the 2nd O2 sensor. Turns out I didn't plug it in all the way.
The D4 light doesn't blink when I turn on the car, it just turns on with the CEL, then they both turn off.
****... I think not filling the torque converter with fluid is my problem... I thought it would fill automatically. How much do I need in there?
I realize that, but I thought those two holes on the end of the shaft that the torque converter sits on would fill the converter.
have you checked the fluid level after driving it? Because after you drive it a little bit it should be way low and then you have to fill it back up again.
just tell your wife you installed a high performance transmission, and it shifts hard cuz its "power shifting" lol...
I'm going to put the old solenoids on the trans + see how that goes.
After driving for about 50mi or so, the check engine light came on. I pulled the code + it says 70 (7 long blinks) but that's not in the guide on this forum so I'm not sure what it is. The D4 light also blinks while I'm checking the code. Anyone have any helpful info on this?
I'm really not sure. It's stock so what ever came with the car. It has the blue two prong plug under the passengers side and that's how I've been checking codes for it.
i didnt look at the year
does it have a cable that runs from the throttle body down to the transmission???
i mean like the throttle cable... does it continue past the throttle down to the trans?
nevermind, its an ek.
probably shifting stiffer from dropping new fluid in it
Try some lucas fluid. it supposed to stop hard shifts. that or u got a bad tranny. or you have a mean *** shift kit and u didn't know it had it lol.
Well if its OBD2 pull the codes with a code reader, it will give you a more specific code. You should have the OBD2 plug by the fuse box.
I swapped out the anti lock solenoid and the shift control solenoid and the CEL went out but it's still shifting hard. I'm going to have the guy at aamco check it out tomorrow.
ferio252
05-08-2008 10:35 AM
