95 si VSS problem
95 si VSS problem
my ex has a 95 si with a b16a swap. the speedo and temp gauges do not work for some reason. im guessing the VSS. but any reason why the temp wouldnt function?
if anyone can let me know how to tell whats goin on i'de appreciate it.
Re: 95 si VSS problem
pull the plug on the vss and make sure its not corroded, make sure none of the wires popped out. Switch it with the single cam one, still not working try to reground the plug. do the same with the coolant sensor
location of the VSS is on the rear of the tranny right? i've heard this before, sorry if im wrong. also, where would the coolant sensor be?
(im not familiar with DOHC's)
my next guess would be that the cable came unplugged behind the cluster? the speedo used to work not that long ago so now im really stumped.
im also spitting out white/grey smoke from the tail pipe, smells nasty, thoughts as to what seals i could have possibly blown?
i just saw on another thread that fuse 15 controls the speedo. i actually checked all fuses under the dash but nothing was blown. then again, there were open slots so i'll have to double check what numbers they were.
http://media.honda.co.uk/car/owner/m...pdf/23-a36.pdf
this shows slot 24 using the VSS, slot 15 says "gauge assembly". this car has SRS and i guess that makes a difference in the slot orientation.
alright well the fuse for the VSS is good, the connector is still seated properly, i have no clue what else it could be. the speedo used to work not that long ago.
bsmith628
11
08-03-2007 01:58 PM
