AM i over doing it??
Old 04-12-2005, 10:45 AM
Mattmob's Avatar
Location: Where we rock teh dookies, Nor Cal, You Es of EY
Default AM i over doing it??
Im getting a JDM D15b vtec and would it be a good idea to get all new gaskets?
The motor is guaranteed to have 60k or less with most likely 30k or less.
Am i going over board by changing all the gaskets before the swap?
Old 04-12-2005, 10:49 AM
POE
POE's Avatar
which gaskets are u replacing, If u ask me i think it sounds dumb. you even gonna replace that head gasket?
I love to drive
Ghetto Civic HX's Avatar
Default Re: AM i over doing it?? (Mattmob)
I don't think so, and besides, unless your getting an entire front clip, it will be almost impossible to "guarantee" the mileage.
Old 04-12-2005, 10:52 AM
-[95cxhatch]-'s Avatar
its never a bad idea to replace gaskets, in my opinion now would be the best time to do it. The motor is not in the car making it easy to access any part of the motor instead of craming your hands down into tight spots etc.
POE
POE's Avatar
Default Re: AM i over doing it?? (92lxsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan &raquo;</TD></TR><TR><TD CLASS="quote">its never a bad idea to replace gaskets, in my opinion now would be the best time to do it. The motor is not in the car making it easy to access any part of the motor instead of craming your hands down into tight spots etc. </TD></TR></TABLE>
i do agree with that
Old 04-12-2005, 10:55 AM
red4's Avatar
since you're getting a new engine for the car, and truthfully have no knowledge of how it was treated before you, i would say changing all the gaskets would be a good thing to do.
you wouldn't want to build a building on a shoddy foundation, would you? same applies here. make sure your base is strong before you go adding mods and other things.
Old 04-12-2005, 11:17 AM
Mattmob's Avatar
Makes sense, thanks guys.
Old 04-12-2005, 11:19 AM
Mattmob's Avatar
SO i guess my nex t question would be;
WHich gaskets to use? I was told to use a d16 gasket on the head, but what about the other areas such as IM and exhaust manifold?
Thanks again!
Old 04-12-2005, 11:20 AM
Motorhead
Guest
Posts: n/a
Default Re: (Mattmob)
It certainly wouldn't hurt, better safe than sorry.
Old 04-12-2005, 01:25 PM
Mattmob's Avatar
Anyone know what gaskets?
Old 04-12-2005, 02:05 PM
cool guy name
Sehc Tib Alli Zerif!!!!!'s Avatar
I'm gonna go against the crowd on this one. I wouldnt change the head gasket(if its not broke dont fix it), if the gasket/seal is not leaking then i wouldnt worry about it.
Now timing belt and water pump I would do.
Old 04-12-2005, 04:49 PM
dohcVTECeg2's Avatar
Default Re: (walker111)
i dont think its a bad idea. actually i think its playing it safe.
Old 04-13-2005, 08:15 AM
cool guy name
Default Re: (dohcVTECeg2)
if you feel like ripping down the motor then knock yourself out, is it necessary? Prob not unless there is an obvious problem.
Timing belt and water pump are crucial to making your engine work, if the timing belt goes the motor goes.
Old 04-13-2005, 08:17 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">if you feel like ripping down the motor then knock yourself out, is it necessary? Prob not unless there is an obvious problem.
Timing belt and water pump are crucial to making your engine work, if the timing belt goes the motor goes. </TD></TR></TABLE>
yeap. i'd do the rear main seal, waterpump, t-belt. the headgasket isn't any harder to do while the motor's in the car.
iHEARTMYCiViC
Northwest (Sales)
01-10-2010 10:26 AM
ReactioN
30
09-06-2008 10:42 AM
jdmjunkie8
12-31-2007 07:44 PM
Dj^BaNNeD
04-21-2007 04:09 PM
labatia
04-15-2004 09:17 PM
Quick Reply: AM i over doing it??
