airbag replacement tray ?
Old 01-03-2005, 01:36 PM
wifesaynogo's Avatar
Default airbag replacement tray ?
will an airbag replacement tray for a dc2 or an ek9 fit in the eg dash? the search is down when i looked
Old 01-03-2005, 06:17 PM
Default Re: airbag replacement tray ? (wifesaynogo)
bump
Old 01-03-2005, 06:29 PM
DiSbaDbOi's Avatar
i think the dc2 and the ek9 trays are a little wider...im not even sure if the dc2 and ek9 trays are the same size...
Old 01-03-2005, 06:35 PM
B2FiNiTY's Avatar
It will not work.
Old 01-03-2005, 07:52 PM
JibOnALib's Avatar
Default Re: airbag replacement tray ? (B2FiNiTY)
It will work...I have it sitting in my dash right now.
I wrecked my car and the airbags went off...and I decided to just put the tray in there instead of an airbag cover. (i just wanted something different and I thought it was cool) I was told that it fits just fine and you wouldn't have to modify anything. Well the tray was too wide (not length but the width, from the front of the dash to the back towards the windshield) so i just took my grinder (since I had it there to clean up some welds on my core support.) and grinded off about a 1/4 of an inch and it popped in fine. Then I sealed it down with a lil shoe goo and it looks great.
Even the guys at my work (hate honda's just because of the reputation) like it and think that the block off tray is tight, even though I just bought it because I felt like using that instead of a airbag cover. But yes it will work, and I'm sorry I still don't have any pictures (like 3 different people have sent me messages.) The only hard part is getting the old airbag cover off. the rest is pretty easy. Good Luck!
Old 01-03-2005, 08:08 PM
Default Re: airbag replacement tray ? (JibOnALib)
jibonalib i pm'ed you
Old 01-04-2005, 06:06 PM
longbeachpurplecivic's Avatar
which tray did you use?? i have a ek tray.. and you just need to grind the topleft corner a lil to pop in place
Old 01-04-2005, 06:21 PM
i have the dc2 tray...do you have to remove the metal frame inside the dash that holds the top of the airbag to?
Old 01-04-2005, 08:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wifesaynogo &raquo;</TD></TR><TR><TD CLASS="quote">i have the dc2 tray...do you have to remove the metal frame inside the dash that holds the top of the airbag to?</TD></TR></TABLE>
yea i removed all passenger airbag hardware stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JibOnALib &raquo;</TD></TR><TR><TD CLASS="quote">It will work...I have it sitting in my dash right now.
!</TD></TR></TABLE>
and which one did you use?
Paul1985
109
10-07-2017 10:18 AM
fireblaze2k1
27
02-06-2016 04:44 PM
KCustoms
07-21-2010 11:24 AM
DAJay93
Paint and Body
12-03-2007 06:48 PM
DAJay93
12-02-2007 09:18 AM
Quick Reply: airbag replacement tray ?
