Air Conditioning question...
Is the AC setup the same for all 96-00 Civics? I have an EM1 and I need to get pretty much all of the AC wiring for my car. My local yards will likely only have non-Si models laying around. Can the wiring, relays, and pigtails be used from these cars? Thanks.
Re: Air Conditioning question...
I'm new here, just found the site via a google search. I'm working with a 92 Civic LX, last year the air conditioning began failing and finally got to the point where if I pressed and held the recirculation switch on the dash the air conditioner clutch would pick and produce nice cold air. However, this year my work around of holding the recirculation switch no longer works. I've measured 14 volts at the pressure switch (unplugged it and measured voltage there). I have shorted the clutch relay and the clutch energized, when I shorted the pressure switch the compressor fan ran. I have also tried replacing the climate control unit to no avail.
Any suggestions?
Any suggestions?
1999civiclx4dr
Honda Civic (2001 - 2005)
10
08-03-2013 05:34 AM
FR-MOB: ThE bEe GuY
07-23-2005 12:43 AM
