Aftermarket flywheel needed for a stage 4 clutch?
Getting a stage 4 six pick clutch kit for my si. Should I buy a competition fly wheel with it or should I keep my stock b16 flywheel and just get it resurfaced ? Does it make a difference ?
Re: Aftermarket flywheel needed for a stage 4 clutch?
You don't *need* an aftermarket flywheel for any clutch, but you should remove it, have it resurfaced, and replace the flywheel bolts while the clutch is off. The lighter your flywheel, the faster your car will be able to accelerate, but a lightweight flywheel will reduce low speed/low RPM (think parking lots and stop-and-go traffic) driveability. Also, if you have a turbo, stick to a stock-weight flywheel.
For daily driving, I would stick with just getting the stock flywheel resurfaced. The Fidanza B16A2 flywheel weighs 7.5 lbs. The Fidanza I have weighs in at 6.8, and it's noticeably unpleasant to drive at low speed/low RPM. Acceleration gains will be minimal, and negligible.
X2
you do know those wear faster then a fullface right ? and is plain over kill https://honda-tech.com/forums/acura-integra-6/puck-vs-fullface-clutch-3177953/
X2 you do know those wear faster then a fullface right ? and is plain over kill https://honda-tech.com/forums/showthread.php?t=3177953
treborpaul
04-20-2009 05:08 AM
