AC probs AC goes on my its self read inside
Hey guys my 99 civic or El same ****
driving it yesturday no ac on and i noticed the air coming out of it was super cold so i was like wtf pulled over and as soon as i shut the car off there is a valve at the bottom of the car that shot out some oil and freoon and i had to cut the belt ff cause the ac compressor would not shut off well the compresor is fint but for some reason the ac kits on and it shots my rpms up.. Is there a main relay in these things ir something any help
Re: AC probs AC goes on my its self read inside (JDMCRX)
What year car is it? I ask because the internals in the cabin are either vacuum or electronicly controlled. Either way tho the Ac is controlled by a switch on your climate controll which needs the fan to be running on a setting greater then the off position.
edit: somehow I completly missed the first line lol, let me check for you
Ok there are two relays, both appear to be located near the ac compressor,
one has wht, blu/blk, yel, and yel/blk - condensor fan relay
the other has wht, red, blk/yel, and blk red - Compressor clutch
Re: AC probs AC goes on my its self read inside (nocturnaldragon)
Man ive looked on the car its a 99 and its by the compresor but there is a relief valve on the ac compresor if the presure gets to hight right??
Cause basicaly ill be driving and all a sudden i get to a stop sign my revs are high so i push the ac on then off and the revs go down.
I dont so much think its an relief valve if it looks like the stem on your tires thats where they fill the system, but im not all that familier with the Ac system, Im excellant at electrical trouble shooting tho
NO the white mist and comp oil cam from the bottom of the compressor or the back side of it **** was coming out there is still presure int he system..
But here is the question
Say if the comp relay were to close contacts and the compresor was powered would there be a signal from that relay to the ECU on the car for it to speed up?. Im wondering cause the pump engages and the cars speeds up.
What happend was i think the relay is fucked and it was engaging the clutch on the comp and the system was over heating cause the fan was not running so there is a relief valve on the compresor that relases so much pressure to prevent damage.
josh
josh
I dont think so, its a closed system and you dont want that stuff going into the atmosphere let alone people breathing it. Pull the relay once and see what happens, you can then use a test light to see if the relay is being powered or not and then know which end of the system to trouble shoot, Otherwise the compressior clutch might be stuck on.
broken_honda
06-26-2018 03:17 PM
PL_RACER
Honda Civic (2006 - 2015)
07-24-2012 07:20 PM
Civic Racer X 7
08-08-2007 05:15 PM
