ac compressor makes noise
Old 08-14-2011, 11:28 PM
the soL that could's Avatar
Icon6 ac compressor makes noise
screeching ... basically, higher RPMs = louder/prominent noise. what is wrong with it?
i have a used compressor i want to swap in, but i rather leave it all untouched and fix the ac compressor while it is attached to vehicle with refrigerant still in system (stuff is expensive).
Old 08-15-2011, 04:01 AM
strategy400's Avatar
Default Re: ac compressor makes noise
Loose belt?
(Now accepting my 2nd annual Capt. Obvious award).
Old 08-15-2011, 08:37 AM
Originally Posted by strategy400
Loose belt?
LoL
no... not loose belt.
The Grumpiest
grumblemarc's Avatar
Bearings.
Old 08-15-2011, 11:29 AM
Originally Posted by grumblemarc
Bearings.
- is this serviceable?
- or should i replace compressor?
it all works... just makes noise and car runs like crap with it on.
Old 08-15-2011, 12:02 PM
Do you hear the screetching constantly or only when the compressor turns on/engages?
Old 08-15-2011, 12:10 PM
DO/\/\O's Avatar
I had the same problem at one time.. it was the pulley and the bearing that goes in the middle
hope it helps
Old 08-15-2011, 12:17 PM
Blacknight117's Avatar
Same thing is happening to me, the compressor is making a screaching noise. It could be that the bearings are going, like grumblmarc said. Just make sure you get it serviced soon because if the compressor seizes, than you could have more problems.
Old 08-15-2011, 02:54 PM
i called the dealer and they said they only service the "clutch" etc... the bearings are in the idle pulley right?
DeeJaayM
Honda Civic (2006 - 2015)
07-16-2018 08:16 PM
Crobran
02-09-2017 12:37 PM
plotomatic
09-24-2016 11:10 AM
Hernst
Honda CR-V & Element
09-22-2015 02:22 PM
Quick Reply: ac compressor makes noise
