About axles
Re: (marc-111)
drivers side is different because they both use different intermediate shafts. the gsr intermediate shaft has a male end where the axle goes into and the b16a shaft is female where the axle goes into
Re: (solareclipseauto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto »</TD></TR><TR><TD CLASS="quote">drivers side is different because they both use different intermediate shafts. the gsr intermediate shaft has a male end where the axle goes into and the b16a shaft is female where the axle goes into</TD></TR></TABLE>
this is true for the obd0 b16a... the b16a2 and a3 axles will work on the drivers side with the 94 up gsr intermediate shaft
Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">
this is true for the obd0 b16a... the b16a2 and a3 axles will work on the drivers side with the 94 up gsr intermediate shaft</TD></TR></TABLE>
Re: (marc-111)
the splines are the same... only difference i know of is the abs one has a ring on it for the wheel sensors... if your car has abs then yes you should get the corresponding axle... if you dont have abs then it doesnt matter
Re: (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 »</TD></TR><TR><TD CLASS="quote">the splines are the same... only difference i know of is the abs one has a ring on it for the wheel sensors... if your car has abs then yes you should get the corresponding axle... if you dont have abs then it doesnt matter</TD></TR></TABLE>
got it thanks!
got it thanks!
wrenchez81
12
08-08-2009 01:17 PM
