AXLE help ASAP
Old Aug 15, 2003 | 01:43 PM
7PSiEF9ZC's Avatar
Default AXLE help ASAP
I have a 91' Civic HB with a B16 in it/ I'm using a YS-1 trans. The passenger side axle does not sit all the way in and seems to almost pop out and it's LEAKing really bad. I'm using 90'-93' inetgra axles and I removed the spacer and dust sheilds from the inner hub Why is this not fitting right. What do I have to do or what axle do I have to use. The driver side with the intermediate shaft sits fine it's the other side. I need help ASAP> Thanks.
Old Aug 15, 2003 | 02:23 PM
tegmech's Avatar
It is because your axles are not put in the way. if the tranny is for abs you need to use the ring on the axles. It is a pain in the *** to get them in but you have to. Also you may be using the wrong axles. If you have abs and you don't have the abs ring i don't think they will stay in there. Check that first, i am in a hurry so im think i explained it right. hope this helps.
eggsi619
Oct 26, 2009 09:37 PM
alscrx
Apr 18, 2009 04:43 PM
S13 slide
Jun 1, 2004 11:03 AM
SikofFalln
Aug 7, 2003 02:05 PM
