99 civic si - can't communicate with the ECU
hey guys, i just bought another civic si with some mods on it already, one question though, i tried doing a scan for any codes in general & i couldn't connect to the ecu, i'm thinking the previous had the ecu reflashed or remapped .But there's no problem with the car though, it drives find.
Any suggestions, what'z going on guys?
Re: 99 civic si help
Take off the passenger side kick panel. There will probably be a obd2b to obd1 jumper harness with an obd1 ecu (most likely chipped). Or... check the "back up" fuse in the engine bay fuse box and see if it is blown. Should be a brown 7.5 fuse. Check all fuses just in case, but i think it's the back up one that saves data and controls the ecu being able to be scanned.
Re: 99 civic si - can't communicate with the ECU
Yeah the back up fuse supplies power to the DLC that thing you plug the scanner into for the ones that dont know what a DLC is and it may be blown. That or it has been converted to OBD1 and since OBD1 does not do live data and code reading like a OBD2 one does it will not work with a scanner.
thanks alot, fuse 43 it is, im gonna check it in the morning, yea i think the car was chipped before i got it, cause it came with injen cold air intake, integra intake manifold, dc headers & apexi exhaust ( i think itz catback, gotta check)... im not really worried, i would like to be able to give the car an overall scan to make sure everything is ok, you know what i mean.
Alright thank you, i will do that in the morning, thanks again for the info, i wont worry about too much... because im planning on doing a integra type r swap...
If you loved me, you'd all sell me your magic cards to me today
Use this to help for the ECU identification
http://www.hondata.com/techecuid.html
Also if it is a JDM ECU it will never communicate as well.
Kid-jdm-teggy
17
01-28-2015 08:57 PM
