99 civic si Auto vtec-e
hi i have a 1999 honda civic si automatic
the bottom end is blown and i just want to replace the motor, i was told the motor is a VTEC-E and i am wondering if i can swap in a regular V-TEC or a non vtec without any wiring issues or any other issues that will throw a code and not allow me to pass an estest (in canada due to new OBD2 restrictions)
what is the difference between vtec-e and vtec? is it wiring, or internal?
thanks for any info you may have!
RoRo
RoRo
Seagull Management
Re: 99 civic si Auto vtec-e
The engine should already be a regular vtec engine unless it was swapped. What does the block stamp say? It should be stamped D16Y8 where the block meets the transmission.
It is a d16y8 but the auto wrecker we called for another motor asked if te 6th digit on the vin was a 6 or a 7 , it's a 6 and he said it was a vtec-e so it threw me off a bit, I know the blocks are the same Im just wondering if the vtec e has any different wiring or if a regular d16y8 will be fine or a straight swap
Seagull Management
6 is D16Y7 (non-vtec engine found in most '96 - '00 Civics)
7 is D16Y5, Vtec-E, found in the HX coupe (US only car and engine)
8 is D16Y8, SOHC vtec, found in the '96 - '00 Canadian Si/US EX
1 is B16A2, DOHC vtec, found in the '99 - '00 Canadian SiR/US Si
If your 6th digit is a 6 then its not an SI. SI's(EM1) came with the b16a2 motor which was VTEC. If your 6th digit is a 6 then its an ej6, meaning the car is a DX or LX model (which has the d16y7 motor) the EX model is the ej8 which has the d16y8 VTEC. Also SI's came only with 5spd tranny's, Sorry but i dont know who told you that was an SI
sorry my bad the wrecking yard asked if the 6th digit was a 7 or an 8 and it was an 8
And the badge on the back told me it was an si, I know my Hondas, like I said before when he said its a vtec e it threw me off
thanks for the info , will be grabbing a d16y8 tomorrow
