99-00 Si IAC valve question
I have a 99 Si and the IAC valve code is being thrown. I was just wondering if I have to get an IAC from another 99-00 Si or are there other motors out there with the same IAC valve as mine (ex. B series motors)? Just so I can call a few junk yards and let them know what I am looking for and from what cars they can come from.
Thanks
Thanks
Honestly not yet....I recently turboed the car too. I will do that definately before I decide to just by another IAC....but just in case it is bad I just wanted a heads up of what other IACs are compatible with the B16A2.
Re: 99-00 Si IAC valve question (Skillz)
Take off the valve and clean the screen. Do you happen to have a cold air intake? That usually causes newer vehicles to start throwing the IAC code. Usually if you set the idle speed again (correctly), it will go away. 95% of the time, its not the valve itself.
Re: (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">I believe honda only have 2 kind of iacv. not positive but i think B and D are interchangable and F and H are interchangeable</TD></TR></TABLE>
some d series are not interchangable with b, some d series use a 3 wire rotary type... like on my dx civic , which I had to get re wired to 2 wire IACV for my b16 swap
I'm not throwing any cel's but i believe my IACV is messed up because I have a horrible idle problem that goes away when the car is on and I unplug the IACV.
If i take it out and clean the screen and it doesnt help, i'd also like to know which one's i may be able to replace it with...
thanks.
thanks.
Re: (eL)
Anyone have a problem with this email me i got a great site that goes threw the list and you will 90% fix the problem. I fixed mine but mine was easy..
let me know ill send you the site info..
seadoopartsforsale@sbcglobal.net
jeff
jeff
Re: (jdm gsr lsd tranny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm gsr lsd tranny »</TD></TR><TR><TD CLASS="quote">Anyone have a problem with this email me....</TD></TR></TABLE>
Why not do the HT community a favor and just post the link?
