98 ex with aftermarket head unit power lock question
ok so im installing an aftermarket head unit in my g/fs 98 ex civic i have been told that removing the stock radio will disable the power locks unless i do something with the stock radios wiring. is that nayone who can be more specific in what that particular trick is. also there is an automatic starter system installed in the car as well. they have the power locks on the starter system. have they bypassed the stock radio system anyways or no. any help will be appreciated thanks
Re: 98 ex with aftermarket head unit power lock question
Using an aftermarket head doesn't disable the power locks, it disables the remote keyless entry (the receiver is built into the stock head unit).
and you will need to connect two wires on the green security plug in order for your dome light to continue working
is there a way to continue keyless entry with the aftrmarket unit at all
H-T White Ops
You can get a radio harness that's meant to keep the dome light working and meant to keep the stock radio hidden behind the dash.
IIRC, InstallDr.com has instructions on hiding the radio and such too.
i got the merta calbe that splits the two head units and you can hide the other one ordered now. but ultimatly i was wonding if the aftermarket auto starter had its own receiver. its an AVITAL starter system.
EXrated
Audio / Security / Video
08-24-2005 12:42 PM
cilvia
07-07-2005 01:11 PM
ccivic
10
05-23-2005 06:57 PM
