98 Civic LX - Help identifying rear brake part.
I bought it used last year and so far I've had no issues with it at all. Until the rear left brake line corroded to the point that it broke. Thankfully, I was parked at the time. I took both bad rear brake hoses off and inspected the front, which looks good. I ordered the replacement parts for both rear brake hoses but it seems the they are different. The only hose available either on-line or at regular auto stores is just a rubber hose but the one I took off is made up of rubber and metal line (check out the pic).
The part that I can't find anywhere is actually the part that ruptured. It's a metal U shaped tube, very similar to the brake line that runs under the car. Even the service manual I have access to doesn't show this part.
Does anyone know what it is and if it's OEM? If not, is there any option to replace it with anything else?
Re: 98 Civic LX - Help identifying rear brake part.
it is oem. you're either going to have to buy one from a honda dealer, make your own, or find one at a junkyard.
http://www.hondaautomotiveparts.com/...y5=BRAKE+LINES
pillchek
11-09-2012 02:05 AM
t-rd
07-24-2006 04:38 PM
