How to remove emblems?
Old Dec 7, 2003 | 11:31 PM
Mason Dixon
Guest
Posts: n/a
Default How to remove emblems?
How do you remove the emblems?
Old Dec 8, 2003 | 12:58 AM
2000Accord5sp's Avatar
Default Re: How to remove emblems? (Mason Dixon)
dental floss
Old Dec 8, 2003 | 01:06 AM
KTeller8's Avatar
Default Re: How to remove emblems? (2000Accord5sp)
yes dental floss will loosen up the glue
then pull them..
Old Dec 8, 2003 | 07:57 AM
t_e's Avatar
t_e
Default Re: How to remove emblems? (KTeller8)
use a heat gun and warm the emblems up and then use dental floss... dont use a credit card it scratches the car
Old Dec 8, 2003 | 09:56 AM
.bagged's Avatar
Default Re: How to remove emblems? (t_e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t_e &raquo;</TD></TR><TR><TD CLASS="quote">use a heat gun and warm the emblems up and then use dental floss... dont use a credit card it scratches the car</TD></TR></TABLE>
once the badges are off you will be left with a residue. dont use a tar or adhesive remover some times these are to aggressive for most clear coats. stop by a local paint store for rubbing compounds that they recommend..
Old Dec 8, 2003 | 10:15 AM
The_Todd's Avatar
Farts in the shower
Default Re: How to remove emblems? (bagged93accord)
Ya be careful using a heat gun...you can melt/burn the paint....and use dental floss just because some of the emblems have little plugs that stick into the body work, floss with loosen up the surrounding sticky and you should be able to take them off, try using a low end adhesive remover like wd40.....KIDDING, some vinegar mix with water works ok, and repeated car washes and your body work shop should have a compound that they could recommend too....also if you dont get those holes filled you can end up with rust or nappy-ness.....getting them filled looks way better than having holes in your trunk lid IMO.
Old Dec 8, 2003 | 10:24 AM
j-bird's Avatar
Use a hair dryer, it won't get hot enough to damage the paint and just hot enough to loosen the glue. I also used a product called Goo Gone on the residue, won't damage the clear coat or paint.
Old Dec 8, 2003 | 10:28 AM
WongFeihung's Avatar
Default Re: (j-bird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-bird &raquo;</TD></TR><TR><TD CLASS="quote">Use a hair dryer, it won't get hot enough to damage the paint and just hot enough to loosen the glue. I also used a product called Goo Gone on the residue, won't damage the clear coat or paint.</TD></TR></TABLE>
yep, good gone works well in taking off the left over residue.
Old Dec 8, 2003 | 10:31 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: (WongFeihung)
That's wierd, no one told him to search
And it's his first post... WTF?
Old Dec 8, 2003 | 11:08 AM
KTeller8's Avatar
Default Re: (ophdehEEzY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ophdehEEzY &raquo;</TD></TR><TR><TD CLASS="quote">That's wierd, no one told him to search
And it's his first post... WTF?</TD></TR></TABLE>
Tis the season to be nice..... we are trying to set a new level in the accord forum...
ps. on the next question, we will slam him with the search answer!
likeahstone
Paint and Body
Aug 26, 2008 12:18 AM
gutted-dx
Oct 1, 2005 01:44 PM
B18CR-X
Apr 1, 2005 09:33 AM
Honda_18
25
Dec 5, 2004 02:38 PM
Steve
May 14, 2001 01:17 PM
