What should i use to remove civic sticker from trunk
Old 10-01-2005, 08:55 AM
gutted-dx's Avatar
Default What should i use to remove civic sticker from trunk
The sticker is all messed up and is was going to put a new one on.
Old 10-01-2005, 08:58 AM
komat's Avatar
Default Re: What should i use to remove civic sticker from trunk (gutted-dx)
heat gun
to remove the sticky stuff use goo gone or wd40
Old 10-01-2005, 09:25 AM
skip.two's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">heat gun</TD></TR></TABLE>
this or a hair dryer will work
Old 10-01-2005, 09:26 AM
Luserkid's Avatar
Default Re: What should i use to remove civic sticker from trunk (skip.two)
Also a razor blade.
Old 10-01-2005, 09:31 AM
hushypushy's Avatar
or fishing line
Old 10-01-2005, 09:46 AM
E46Kid's Avatar
are u talken about the emblem? if so what i always did was remove the emblem and get a rag with soap and start rubbing it if u use razor blade i would think u would scratch the paint and if u use a heat gun u could melt the paint so solution is clean cloth and rub it out
Old 10-01-2005, 10:06 AM
bluebird's Avatar
Default Re: (00EM1)
use peanut butter... it will eat all the glue away....
Old 10-01-2005, 10:22 AM
romJones's Avatar
Default Re: (bluebird)
as far as getting the emblem off.....u could also use dental floss
the sticker...
jus do ur best and peel away
as far as getting rid of the goo residue...
i used nail polish remover
works wonders!
Old 10-01-2005, 01:38 PM
gutted-dx's Avatar
Those stickers are a bitch to peel off
Old 10-01-2005, 01:44 PM
Vintech's Avatar
Default Re: What should i use to remove civic sticker from trunk (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Also a razor blade. </TD></TR></TABLE> WRONG
Unless it's a plastic razor blade
I work in a Body Shop
To get off stickers best bet is a heat gun. Heat it up but not where its to hot too touch. You really don't need a heat gun but it makes it go faster
For Emblems floss works good but then your left with a foam mess, thats when you bring out the heat gun.
Your finger nail is the best tool you have.
To get off the residue, if any, go get some adhesive remover which can be found cheap at any parts store. Or you could use nail polish. I've never used this ,but it could be used, my advice for it is use sparingly.
carboncivic
12-30-2006 02:05 PM
kniob
07-13-2005 11:22 AM
Honda_18
25
12-05-2004 02:38 PM
gribbs
04-27-2004 11:14 AM
Mason Dixon
12-08-2003 11:08 AM
Quick Reply: What should i use to remove civic sticker from trunk
