97 honda civic auto to manual swap help.
I just swapped a 5spd in my civic but now I can get the key out.. I hooked the neutral safety switch wires together. I also hooked what I think was the wires to tell the pcm that the car was in park ttogether.they were a black wire and as green wire with a white stripe but it still won't come out.. any ideas
I'm not Rick!
Re: 97 honda civic auto to manual swap help.
the problem is not electrical .
its the wheel lock. it happens.
do yourself a favor.
take off the plastic column trim.
directly under the steering wheel. on the ignition tube.
in the middle is a washer pressed into the middle....thats whats holding your wheel lock in.
take a screwdriver or punch. hammer it into it. brake it out. a spring will fall out. your wheel will be free..but so will the key.
Everything i read said to hook the two wires that i did together. So i was just trying to see if anyone has ran into the same problem
Your going to have a 2 thick blk wires and 1 blk/blu wire, Solder those 3 together. Those together lets your car think its in park and releases the key and starts your car
OneFreeMan
Honda Civic (2001 - 2005)
05-25-2016 08:20 AM
Ek9andyroo
06-26-2009 12:29 PM
IOSUA
10-06-2007 05:44 PM
DC5Danny
14
07-18-2006 08:16 PM
CIVIC97KA
05-01-2004 09:22 PM
