96 Civic has 99-00 climate control - how do I make it work?
96 Civic has Obd2b body harness want to swap d16y5 - how do I make it work?
I bought a 96 civic hatch shell. It was a stolen recovery. When I went to put in the y5 I noticed that the previous owner switched the interior to obd2b. The air mix control has a motor on it. I need to know how I can get this to work. Thank you in advance.
Re: d16y5 into obd2b
Always start by looking in the FAQs sticky. There, you'll find this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-%2A%2A-mother-all-how-tos-96-98-ek-manual-climate-swap-99-00-ek-electronic-%2A%2A-605432/
Re: 96 Civic has 99-00 climate control - how do I make it work?
Sorry, I wasn't very clear. I want to figure out how to get the engine to work properly in the vehicle. As it stands I will have two A connectors. My main question is when I depin the A connector that is in the cabin can I just splice the wires into the corresponding wires the connector from the engine bay or should I remove the pins from the other connector and insert the pin from A connector in the cabin. Looking a the diagrams in the manual I cannot be sure where the signals originate. I am worried that if I splice into the wire the ecu may get the signal from two places and get screwy or that if I depin the another connector to put in the pin from the cabins A connector that I may be removing the signal that the ecu would have been getting anyway.
<ivi>si
07-16-2012 10:29 PM
dorifto_83
10
03-11-2008 08:51 AM
Kyo Babic
08-13-2007 09:12 AM
93Civac
08-30-2004 03:48 AM
