96-00 civic with b18b swap with bolt ons helppppp
Old 01-28-2011, 11:46 PM
Jestin25's Avatar
Icon2 96-00 civic with b18b swap with bolt ons helppppp
okkkkk i no evey bodys herd this 16516310656510600650650654030610616016551 times but i cant get a good answer i wana do the swap to my 97 civic coup and whould there be a big diffrence from the d16y8 to the b18b and maybe the 1/4 mile times thank u and im new so thanks guys
Old 01-29-2011, 06:27 AM
buster97's Avatar
Default Re: 96-00 civic with b18b swap with bolt ons helppppp
yea more torq and hp u will notice the difference quick i ran around in y8 for ever untill i got my b16 and love it and ls are nice motors too
just make sure u get the EM1 t bracket that was a pain in the *** to find had to order off inlinefour.com GL
Old 01-29-2011, 08:15 AM
EJ1civic coupe's Avatar
def..its a step up..your comparing a dohc to sohc..of course your gonna see and feel a dif..just wont have vtec..no biggy tho..vtec doesnt even matter in sohc unless its built up alittle
Old 01-29-2011, 12:17 PM
Jestin25's Avatar
thanks alot guys
Old 01-29-2011, 12:19 PM
johnson8861's Avatar
I think the b series sounds better than the d series.
Old 01-29-2011, 11:02 PM
Jestin25's Avatar
and also wounder can i also use the ex wireing and ecu?
Old 03-27-2011, 09:51 PM
Jestin25's Avatar
bump
Old 03-27-2011, 09:57 PM
MiNDTRiP03's Avatar
Use your stock harness, get the Si rear T bracket, and driver side block mount. For the ECU, grab an OBD2A P75 LS ECU.
Old 03-28-2011, 07:29 AM
Jestin25's Avatar
bump
Old 03-28-2011, 07:35 AM
The Grumpiest
grumblemarc's Avatar
He answered you.
You haven't gotten this figured out in two months? In for progress.
Old 03-28-2011, 08:11 AM
Ek Forever y0!
Libertariat's Avatar
-Tires
-Seat time
-Engine condition
-Other modifications
Old 03-28-2011, 08:15 AM
The Grumpiest
^X2 this.
Old 03-28-2011, 08:23 AM
Ek Forever y0!
To give you some clarity, a stock d16y8 probably runs a ~16.7 second 1/4 mile, the car might be capable of a 16.0 second 1/4 mile with the new engine and transmission.
VERY rough numbers based on Compiled Car and driver/road and track data.
Emphasis on the car running the time and not the driver.
Good driver + in a vacuum where all variables are held constant.
Old 03-28-2011, 10:52 PM
Jestin25's Avatar
well with the 1/4 time wats urs on this motor
Old 03-29-2011, 02:34 AM
Ek Forever y0!
No one tries to get serious with stock b-series motors. (B18c5 being the exception) They aren't much faster than a d-series.
They do however respond better to cams, turbos, etc than d-series engines do.
Stock Honda engines are slow. Plain and simple. Unless you get a b18c5 with the J24 transmission or an h2b/k20 build you aren't going to have a "quick" stock Honda swap.
I'm not telling you 1/4 mile times because I have that particular motor setup either, that's based on some stats from albeedigital.com
Quit worrying about 1/4 mile times and get moving on your swap. A b18b is a phenomenal, sturdy, cheap boost motor. Get 200-300whp on a mild turbo setup and get back to us once you get some seat time.
Old 03-29-2011, 03:42 AM
Dukefreshk's Avatar
Throw the d in da trash and go with the b series. I know I love mine.
Old 03-29-2011, 03:54 AM
Ek Forever y0!
I'm not sure I would consider a stock b18b or a b16a a groundbreaking improvement over a d16y8.
That's more what the OP is hoping for it seems. Like a stock b-series swap is going to allow him to own up some late 90's mustang GTs
salisbury
05-12-2010 04:20 PM
PiTony
10-26-2007 01:55 PM
.::miLan
11-15-2005 05:43 PM
BlendedEJ8
10-31-2004 12:18 PM
tolowhb
04-14-2003 09:01 PM
Quick Reply: 96-00 civic with b18b swap with bolt ons helppppp
