95 civic auto ecu
95 civic auto ecu
i have a 95 manual shell with a 94 d16z6 auto swapped in but i do not have the manual ecu my question is would this cause in problems to run the car like this
off the bat the car idles high and has a CEL
also i believe the purge valve for the evap canister locate on the intake mani. would that cause any problems like surging or high idle?
Re: 95 civic auto ecu
sorry i might not have typed it clearly i have the auto motor with a manual trans bolted up (flywheel clutch ext) but i have the auto ecu still i take it i need the manual ecu for it to run properly? but would running it (short term) like this cause any damage?
the motor isnt auto, the transmission is auto. The motor has nothing to do with it. And yes, running a auto ecu on a manuel is going to make it run like ****. No it shouldnt cause any damage short term, but i wouldnt be going around 'beating' on it for the time being.
