my b20 swap parts list
let me know what you think of it. im pretty sure i have everything needed, feel free to let me know if something should be added. prices are probably not entirely correct so bear with me. this is a swap for my 98 civic dx. thanks
item-price-part number/seller
JDM B20B-- 600--
GSR Trans -- 400--
Shift Linkage-- 50--
SI rear bracket -- 44-- 50827-S04-N10
GSR front trans mount-- 60-- 50843-S04-N10
CRV AC Bracket -- 70-- 38930-P7J-000
DS engine mount -- 51 -- 11910-P30-000
PS bracket -- 0--
rad upper hose-- 15-- 19501-P30-000
rad lower hose-- 15-- 19502-P30-000
GSR Axels-- 120--
Oil -- 40 --
Trans fluid -- 20--
coolant-- 15--
Arp rod bolts-- 36-- lightning
phearable chip-- 40-- phearable
clutch kit/fidanza 7.5lb-- 320-- gripforce-ebay
thermostat -- 16-- 19301-P08-316
mount inserts-- 45 -- ebay
water pump -- 78 -- 19200-P75-003
water pump gasket-- 3 -- 19222-PR4-003
timing belt-- 50-- 14400-P7J-004
bottom end gasket kit -- 50-- 06111-PR4-030
head gasket-- 54-- 12251-P8R-004
valve cover gasket kit- 36-- 12030-PR4-000
axel seals -- 6-- 91205-PC9-711
thermal IM gasket -- 35-- p2r
IM -- 0-- David
Plug wires -- 58-- ngk 9259
Spark plugs-- 30-- ngk 6441
LS AC belt-- 16 -- 38920-P75-A02
PS belt --
ALT belt--
Blox drain bolts-- 20-- ebay
b series alt --
b series alt brackets--
RMF replica header-- 375
s300-- 490
JDM B20B-- 600--
GSR Trans -- 400--
PS bracket -- 0--
GSR Axels-- 120--
Oil -- 40 --
Trans fluid -- 20--
coolant-- 15--
IM -- 0-- David
PS belt --
ALT belt--
b series alt --
s300-- 490
getnasty
06-13-2005 03:58 PM
