95 dx oil on plugs, bogging, and white smoke?
like the title say just a drop or 2 of oil on plug wire small amount on top of plug and a lot of unburned oil on bottom but not sure if it leaked from top. car bogs pretty bad when started does not over heat at all oil is clean as can be
Re: 95 dx oil on plugs, bogging, and white smoke?
checked coolant and it looks like it has rusty water in it has a little of the coolant green color
replaced plug tube gaskets and plugs plug closet to dist. is soaked on threads and next one not as bad the third soaked and the 4th next to the timing belt is dry, took on test drive still has white smoke but not at idle only in acceleration took the oil cap off when i got back small amount of smoke came out but oil still looks great no more bogging but i think its because of the new plugs not saturated in oil.. yet
sounds like piston rings or headgasket. I had oil on my plugs and it was because my rings were worn out. How much oil is it comsuming? you need to do a leak down test and compression test first to see if all cylinders are in specs. The leak down should point you in the right direction as to where your problem is.
Peteypablo17
02-17-2013 04:46 AM
Jrox.chase
17
10-30-2011 12:40 PM
