95 del sol wont start. help please
im tryin to help my friend fix his car but it wont start. it just cranks but it wont crank over an after tryin to start couple time it backfires.
wat could it be. thanks 4 d help
Re: 95 del sol wont start. help please
Could be poor fuel or water in the fuel, clogged fuel filter or injector filters.
I'd ask about the distributor first.
timing gun or see if the mark on the crank pulley is lined up with the mark on the side of the timing cover and the distributor rotor is pointing at cylinder 1 spark plug wire...
look the crank pulley have one mark then have 3 lil marks on it,the 3 lil marks are for timmin .14.16 and18 degrees now, the one mark by its self is (TDC) top dead center,now look in the timmin belt cover there is two lil guides .now make sure the crank is on tdc and look at the cam pulley has up mark ,make sure its up,if it is off then your timmin its wrong
