cooling fan not turning .please help!!!
92 civic hatch si cooling fan does work, when wired directly to the battery. but doesn not turn on at all. even when A/C is on. nothing. fuse not blown. but i dont know about the black relay in the underhood fuse box. could this be the problem? how would i test?
any help is greatly appreciated.
Re: cooling fan not turning .please help!!! (antballs420)
Is the car warming up enough to kick the cooling fan on? I have a slim-line fan in my H22 EG, and it rarely needs to be on, due to the fact that my radiator is so large. And, I may be wrong, but is there some kind of cooling fan switch on the Civic, or is it just some other Honda model I'm thinking of?
Re: cooling fan not turning .please help!!! (JDMH22Civic)
Most likely the thermoswitch. Its located on the thermostat housing. It has a 2 pin connector, and is basically a switch to ground.
Easy test: unplug the connector and put a paperclip in the 2 pins to create a loop. Turn key on and voila.
If its not this than its most likely the relay.
NAS95
01-15-2018 01:51 AM
big_jay239b16A
16
05-07-2015 03:31 PM
doggworld1233
08-27-2008 04:23 PM
