Electrical Problem Del Sol Brake Lights always on
Yeah well my brake lights stay on even when the car is off and the parking
brake is up. Replaced fuse. I have to take the batter cable off to prevent it
from dying for the time being.
Any suggestions appreciated. Thanks
Re: Electrical Problem Del Sol Brake Lights always on (Ecskater1313)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ecskater1313 »</TD></TR><TR><TD CLASS="quote">Top your Brake Fluid and the wires that connect to the cylinder :-D </TD></TR></TABLE>
i think he is talking about his tail light brake lamp
check the switch connected to the brake foot pedal, i bet the switch is shorted
Re: Electrical Problem Del Sol Brake Lights always on (BatuKing)
Could even be out of adjustment, Theres two on the sol i believe or is it on the clutch side? eitherway check that. unplug it to see if that fixes the proplem and go from there. Are the lights on there normal brightness or are they dim ?
Re: Electrical Problem Del Sol Brake Lights always on (nocternaldragon)
thank goodness Is earched . . . I have the same exact problem. I ran to the store a few nights ago, came back home, and my cousins neighbor told me my lights were on. I said no ways, so I went out headlights were off, walked to the back of my car and my brake lights were stuck on. I gotta take my battery cable off to to prevent the car from dying . . . what all could cause such a thing to happen?
The lights basically look bright as if you were to step on the brakes at night and they get brighter, well if I hit my brakes now at night nobody can tell if I am slowing down or not since they are stuck at full brightness.
Where exactly is that piece by the brake pedal to check?
1 Post
Re: Electrical Problem Del Sol Brake Lights always on (solbats)
theres a switch behind the actuator arm on the brake pedal. you can adjust it in and out. Thats probably the issue.
Re: Electrical Problem Del Sol Brake Lights always on (Vtec92Civic)
oh FYI you can just remove the HORN fuse under the hood to turn off the brake lights untill you fix the problem.
it was the position of the switch in regards to the pedal. It was pushed back
somehow and the button wasn't getting pressed.
I just secured it back in place and it's fine.
thanks for the responses
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">Actually i said it first </TD></TR></TABLE>
Uh no I did
Uh no I did
Ecskater1313, you need to replace your avatar ASAP.
Man, i love big ***, but that is just to huge/fat
As for brake problem, it is your brake fluid most likely. Mines turns on when i make a sharp turn or i accelerate fast, but i'm too lazy to fill it up.
Re: Electrical Problem Del Sol Brake Lights always on (JDMCRXDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol »</TD></TR><TR><TD CLASS="quote">
As for brake problem, it is your brake fluid most likely. </TD></TR></TABLE>
read above, it was the switch.
to be specific there is a rubber nub in an eyehole that pushes in the brake light switch
turning it off when the peddle rises into it from the floor. Mine got old and dried out
then fell out. I replaced it with a rounded head bolt and a nut.
works great and wont fall out.
Is saw theres a similar switch on the clutch pedal what does that one trigger?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbats »</TD></TR><TR><TD CLASS="quote">
Its the netural safety switch. you know where you cannot start the car unless the clutch pedal is depressed.
sofro123
12
08-02-2020 12:33 PM
si90rex
05-24-2010 07:41 PM
Civic Racer X 7
06-10-2006 09:59 PM
