94 civic hatch has cel and cant find service connector
Ok I read how to pull the codes etc and went to the area where it says the connector should be at and no luck.
There was to connectors that were just hanging there both blue connectors one a 3 wire and the other is. 2 wire. I don't remember the colors for the 3 wire but for the 2 wire one it was black and brown so I figure that was it. So I tried it but when I did that and turned my ignition on the srs light started flashing (keep in mind car doesn't have srs light on while driving). Where else can I look for the connector to read the cel code?
Car info: 94 civic hatch auto
I'll try to post pics of the connector found so far
Re: 94 civic hatch has cel and cant find service connector
Please click on the Codes sticky and read about pulling CEL and SRS codes.
Does your CEL work? Have you checked whether the bulb has been removed or is blown?
Ok here is the deal when the the car is just set on the on position sometimes the cel comes for a lil longer then the two seconds but then shuts off. Now as soon I crank the motor on the cel comes back and stays on. I have no other light on but the cel on.
I didn't have a chance to searching or snapping those pics but I'll do that tomorrow
In post #1 in the Codes sticky, Tip #3 tells you how to retrieve the code in this^ situation.
4DALOOKS92
04-16-2016 07:46 AM
flip_nl
02-27-2010 02:40 PM
