94 Civic Dx Hatch - Gauge cluster with rpms or Tachometer?
I have this speedometer that doesnt show the rpms and it is kind of annoying but i wanted to know what would be better to do. Get a whole new speedometer that has rpms or a tachometer rpm? which one is least expensive and in all of your opinion better?
Re: 94 Civic Dx Hatch Speedometer with rmps or Tachometer
the best looking option would be to buy a gauge cluster with a tachometer built in, and install it. The cheap and shitty way is to buy a tachometer and install on your dash, but you'll be called a ricer
Thanks, thats what i had in mind. Do you know if it would be fairly easy to install the new gauge cluster?
Installing a new cluster is REALLY EASY.
Just take out the four screws. Two top and two bottom. Slide it out and unplug it.
Then do the same but in reverse.
Atleast thats what I did with my EJ8.
Re: 94 Civic Dx Hatch - Gauge cluster with rpms or Tachometer?
okay so i bought a cluster and now i have problems wiring up the green connecter behind the cluster because my harness doesnt have the connector.
The green plug on OEM clusters is unused on DX models. It is for cruise control, which you don't have.
O.G. triple O.G.
Grab a cluster from any '92-95 Civic LX, EX or SI. It's plug and play, no modification needed. They all come with a tach, but the LX has a lower redline compared to the EX/SI.
CA6VTEC
07-16-2008 08:21 PM
prettysweetcivic
15
12-05-2004 03:59 PM
wu tang
08-12-2002 01:43 AM
