92 Civic VX - Driver Side Manual Door Lock
I have an issue with my Civics driver side manual door lock. The lock itself is very flimsy, it doesn't actually unlock / lock the door. I can tell that the rod has separated from the rod. I can lock the door from the outside, but not the inside.
I know that there is a rod that connects to this latch. It feels that the rod is no longer attached, I suspect that the rod is not connected because the piece that has the little hole to attach the rod is broken.
Does Honda sell just the little lock latch or do i have to buy the whole assembly?
Re: 92 Civic VX - Driver Side Manual Door Lock
72125-SR0-A02ZA - RIGHT SIDE BLUE
72160-SR0-A02ZA - LEFT SIDE BLUE
I'm always confused on this one. Which side do I need? It's the drivers side, i'm assuming it's the LEFT side?
Oh look, I can change this
^ Yep, definitely take a look inside. Sometimes it's the little lock **** right by the handle that breaks ... from the symptoms you describe that sounds about right. Definitely hit up a junkyard. In fact, I should be at one tomorrow, I'll have a look for you.
Thanks! I have a blue interior. I need a blue lock ****
i have something similar. i can lock my doors from the outside, but from the inside i gotta pull and hold the handle then lock the door then let go of the handle for the door to actually lock.
Location: Pensacola, FL and every Court House in Louisiana
I am talking about the little plastic clips that holds the rods behind the door panel.
Are you talking about the actual tab that is by the door handle that indicated locked or unlocked? I have blue handles that I am about to swap out for black if interested.
Oh, I want! I want!
Megaton22
06-08-2022 10:49 AM
Takumi Fujiwara
01-05-2006 08:15 PM
Intercooler
11-19-2004 04:07 PM
