5 lug conversion tech!!!! help!!!
ok I got the whoel 5 lug conversion but I don't have the rear trailing arms.....
I have a 97 EK with rear drums, but I salvage those arms and use them with the new rotors.
I may be able to get my hands on some 92-93 rear trailing arms.... Will these work?
HELP!
HELP!
Re: 5 lug conversion tech!!!! help!!! (daddymax)
Do you have the entire hub, caliper, rotor assembly? If so you can reuse your old trailing arm. The swap is just a lot easier if the trailing arm is included. As far as the other question goes 92-93 what? If it is a teg the 92-93 trailing arms will NOT work if it is a civic then yes it will work but why, you have your stock trailing arms and you should be fine.
Nextelbuddy
52
11-06-2005 10:56 PM
bgod
09-26-2004 04:32 PM
EricUSC
11-15-2002 10:18 PM
