5 inch monster tach help
anyone know my my 5 incher autometer tach is off by 700, it shows up as 700 more. ive tried everything. made sure the connection to the wire on the distributor was good, even tried new grounds and power sources, same thing.
once in a long while, it'll jump to normal reading, like once a month, but then it would only stay there for like 2 minutes , haha ghetto
any help would be great! thanks
Re: (stripes777)
yup... i have the same problem... mine is off by like 200 or something, not to huge, but i think i'd rather just sell it any takers? $40.. haha!
Re: 5 inch monster tach help (rodrez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">Are you comparing it to a stock tach? The stock one is usually inaccurate. </TD></TR></TABLE>
if thats for me, then no, because i took it to fuel cut a couple times, , and from what the tach displays, its off...
40 bucks for a monster tach with a light? if so , thats a hot deal man, ill buy another one and put in my dads camry, haha.
its off, i can tell from idle and vtec engagement. sometimes it goes to accurate, but only stays there for a while
its almost like it has 2 modes, perfect, and added 700, lol
Re: (stripes777)
on the back of the tach there are little loop wires that each pertain to what cylinder car u have . for 4 cylinders u need to cut all of them , meaning no wire on the back should be together. all shodl be cut.
Re: (stripes777)
yep. you can.
it's a light blue wire in the back of the cluster.
this wire runs right to the distributor, so there's no need to go all the way there.
that's where i've got mine tapped in at, and like i said...deadly accurate
OG triple OG
Re: (hot_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH »</TD></TR><TR><TD CLASS="quote">my 5" autometer tach is deadly accurate...I'll never get rid of it.
aahh deadly accurate .....mine is too.
you guys that ar having problems could have bad internal coils
Re: (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">on the back of the tach there are little loop wires that each pertain to what cylinder car u have . for 4 cylinders u need to cut all of them , meaning no wire on the back should be together. all shodl be cut.</TD></TR></TABLE>
Yep, that's how my autometer is set up. Cut them all and you should be good.
ya theyre are all cut, except for the 4 needed wires( ground , power source, lighting and ****, and the green to the wire. wuts an internal coil? is that something thats cheap and can be easily changed?
i jus changed my cap and rotor for the dist. but the prob was there way before i did it
vteczone
12-18-2003 08:13 PM
