TypeR sway bar into 5G hatch
I was wondering if anyone as done this install? If so what where the parts needed and how much did it end up costing you? I have checked hybrid honda part list for the install. Do i need all those parts for the install or does it vary with the different models?
thanks.
thanks.
Re: TypeR sway bar into 5G hatch (iwishiwereajap)
You will have to have GSR rear Lower Control Arms and the endlinks and the sway bar itself. I have done it with a GSR sway bar but not a type r but it should be the same way.
if you need the gsr lca's, new sway bar, new endlinks, brackets, bushings, it'll cost more...and dont forget the reinforcement for it
Re: TypeR sway bar into 5G hatch (Rspool)
Not trying to be a dick BUT
You have posted 5 times and started 4 threads about the same topic in 2 forums
(EG & TECH)?????????????????????
Mike
[Modified by rolow, 6:30 PM 9/11/2002]
Mike
I would suggest getting this http://www.beaksproducts.com/eg-quickswap.html , its a pretty good price for everything you get, the type r sway bar w/ all bushings and endlinks and the sub-frame reinforcement kit.
But you're also going to have to get some gsr rear lca's and they go around $50-80.
SO total, w/ the beaks quick swap kit, it'll be ~240-270.
Re: TypeR sway bar into 5G hatch (starang w0ndah)
Steve
Re: TypeR sway bar into 5G hatch (ThunderLips)
Isn't that bar a little too thick for the EG?
I have the ITR rear sway on my del Sol, and love it. Handling it splendid.
Steve
Re: TypeR sway bar into 5G hatch (stevecockrill)
1 Post
Re: TypeR sway bar into 5G hatch (SkyeC)
I'm pretty sure ITR Lca's will work, as they have the endlink hole thingy, and the bar is from an ITR But I got the last itr sway bar in stock from beaks- wahoo!!!
Re: TypeR sway bar into 5G hatch (navin)
You'd almost certainly need different endlink hardware with the ITR LCAs. Dunno what to tell you on that one.
Steve
Steve
they are on a national back-order right now...so if you need one yesterday, 'better call up all the honda/acura parts store right now and if they have one, buy it!
Re: TypeR sway bar into 5G hatch (Doctor CorteZ)
itr rear arms are diff
you need ANY rear lca with sway bar tabs and all the endlinks are the same
the 4DR EX has a rear bar
94-up teg - ALL
whatever Del sol has em
NO hatch EVER had a rear bar in the US.
94-up teg - ALL
Steve
Steve
bakomack
08-08-2009 03:14 PM
JDM_dreamer
01-08-2007 08:17 PM
typeeg
09-26-2003 03:53 PM
