2000 honda civic is lsvtec starting/ running problems
lately the car has had a rough idle on start ups after the car warms up it goes away. sometimes you have to pump the gas a little to get it to start or it will stall out. but today driving to work started up driving fine then the car wouldn't accelerate past 40 with the pedal all the floor at first i thought it was the spark plugs/spark wires but its still doing it even after i changed them. could it be the fuel pump or something?
Re: 2000 honda civic is lsvtec starting/ running problems
i changed the cap and rotor no cel codes if i pump the gas pedal it will start then i have to hold the gas all the way to the floor to get it to run at very low rpm then as soon as i let off it dies. i disconnected the fuel line to see if it would prime and it did
Does the CEL work?
Is there bright white spark at all four plugs?
Have you checked the mechanical and ignition timings?
when i turn the ignition on the cel comes on for two seconds then goes off it is a chipped ecu so im not sure. i cant check the spark as of now cause i have no one to start the car for me while i look for the spark. and i dont know how to check for mechanical and ignition timings
so i looked at the timing belt and there are some teeth missing. Is my motor ruined? i pulled the valve cover and everything looked ok
so the compression test is the only way to find out if the motors gone after the timing belt install
Engine damage does not always occur after the timing belt slips or snaps. Let's hope your engine falls into this lucky group.
tpeter91
10-25-2010 06:33 PM
