2000 Ek Rear top hat bolts seized.
My rear top hat bolts are seized and i stripped out the alan wrench. I can either go to the junkyward and get 2 struts for 30 a piece or maybe get an impact wrench for 50 bucks. What do you suggest.
Re: 2000 Ek Rear top hat bolts seized.
if they're stripped how is an air gun going to help ? just cut them off then grab new tops hats, I see them all the time for sale.
also any air gun for under 300 is going to be junk the only worth while ones are IR.
No the alan wrench part in the end of the shock is stripped. i can take an air gun and clamp the shock and spin it off though... Or hope the ones at the junkyard arent seized
Cool Cool Island Breezes. BOY-EE
If you have new shocks, you can find a way to vice grip the shock shaft. You can use a spring compressor. I have a floor mounted hydraulic compressor....but....I usually just point the spring away from my face and genitals and remove the nut.
Fish Twig
If you can take the stress off of the tophat than the nut won't be so stuck on there. An impact gun might be able to get the nut off but you need to compress the spings to relieve the tophat. Also as someone state, since you're replacing the struts ( and hopefully with new ones ) use a vice grip on the rod itself and do your best to remove the nut, with impact is better.
B serious
20
05-26-2008 05:56 AM
oioioi
08-25-2002 10:21 AM
