2000 Ek coupe low compression ISSUE
Hey guys i have a 2000 honda civic DX coupe, It was low compression in cylinder 1 &3 , I just replaced the plugs and wires, The motor has 212k on it. I am the second owner of the car. My machanic told me that 1&3 have 78psi and 2&4 have 185psi. What could i do to fix this? and What do you think is wrong.
Re: 2000 Ek coupe low compression ISSUE
burnt/warped valves most likely if it's THAT low. Bad HG won't cause number's that low....rings would have to be completely shot for it to be that low again. I'll bet you replaced the plug and wires cause it has a rough idle/slight mis, time to put new valves in not a hard job just some what time consuming.
ok thanks man soo much, Do you happen to have a refrence I could go to, for directions to do this on my D16y7
