2000 civic si - cluster and climate control lights don't work?
Old 06-08-2011, 12:38 PM
sandlot's Avatar
Default 2000 civic si - cluster and climate control lights don't work?
hey guys,
im new to this forum, sorry if its already been talked about but i could not simply find it.
my gauge cluster lights do not work nor does my climate control lights. i took off the cluster and the old owner did some hack job. i wired everything back to its stock location and still nothing.
any suggestions? i also checked fuses but idk which fuses would run the cluster and climate control?
thanks!
Old 06-08-2011, 01:10 PM
Former User's Avatar
Default Re: 2000 civic si cluster problem?
How confident are you that 7.5A dash fuse 30 is not blown.
Is the dimmer switch possibly dialed all the down?
Old 06-08-2011, 01:17 PM
sandlot's Avatar
triple checked, not blown.
and the dimmer switch is all the way up, but maybe the switch is messed up?
when i bought the car it had white faced gauges and it lite up very vaguely. i took off the white face gauges and wired everything back and nothing now. but the climate control never worked.
Old 06-08-2011, 01:19 PM
Pry the switch from the dash and unplug it. Then jumper wire the red wire to the black wire in the connector. Do the lights now work?
Old 06-08-2011, 01:29 PM
sandlot's Avatar
Default Re: 2000 civic si - cluster and climate control lights don't work?
i dont quite understand what you mean? sorry
Old 06-08-2011, 01:31 PM
Use a short piece of wire or paperclip to connect the red wire terminal to the black wire terminal in the free dimmer switch connector -- just like jumping the service connector to pull CEL codes (if you have done this).
Old 06-08-2011, 03:14 PM
sandlot's Avatar
didnt work. i may have done the jumping wrong though.
Old 06-08-2011, 03:28 PM
Did you turn the light switch on? Does the red wire or red/blk wire have voltage to body ground?
ed2
07-05-2010 11:38 AM
mynameisMUDD
12
01-16-2010 02:10 PM
JasonYo
11-30-2009 09:21 PM
VtecCivic93
18
07-24-2009 05:31 AM
JDM_EK_wanabe
09-28-2006 02:03 PM
Quick Reply: 2000 civic si - cluster and climate control lights don't work?
