2 civics same start up problems
I have a 1997 cx hatchback d16y7 and a 1997 civic ex d16y8
They both have identical start up issues: the cx started this issue today the ex has been doing it for months
Start them up and the idle drops immediately and feels like its going to die but once it gets going it seems fine.....but it doesnt do this everytime....idles a tad low on the cx but no drive issues but on the ex with the a/c on when it was warm out it will shake when you stop and kind of goes away when you turn the a/c off...the ex recently had a ignition coil,rotor,wires changed.
Im stumped on this problem they both seem to have smooth power no miss fire while driving its not much to go on but thought id try here ive been googling all day
Re: 2 civics same start up problems
Sounds like you need to adjust the idle on both cars, and possibly remove and clean the FITV on the CX. You can find how-to's for both in the FAQ's sticky, as well as a FSM.
I adjusted the idle on the cx but it went to high like 1500 so i just dropped it back to where the cable didnt have any slack and it seems kind of low.....Ill have to research what the fitv is thanks
I have not cleaned the iacv yet im pretty sure with the luck i have been having lately that would not be the problem lol but i may go ahead and try it on the cx first.
The ex is a long story my gf was driving home it had low power and it shut off on her drive way and wouldnt start back up i researched and ended up putting on a ignition coil and it started right up and that when the ex problems started happening i dont know if i bought a crappy ignition coil it was a brand new rich porter ignition coil people said those wore decent. Ive changed the wires since it had one dead wire when i tested with the multi meter and i changed the rotor in the distributor cap looked good no dust or anything odd looking in it. But still same
Oh on the EX it did have a check engine light but i have not checked it im scared to get stranded on that one on the way to autozone or something lol....but ill have to use my little obd2 thing for my laptop to check the codes havent had time with all the car problems im having lol.
And the CX no check engine light at all but when i turn the key no light comes on either and i hooked my obd2 thing that goes to my laptop and its not communicating
Go to the FAQs sticky. There's an idle adjust diagram for both engines.
And a dirty IACV is probably the most common cause of 96-00 Civic idle problems. Click the link in my signature.
Pull the CEL codes and post them. You just need to jump the service connector.
The CEL bulb in the CX is blown or removed. Replace it. Also check the hood Back Up fuse and fuse 43.
If you were using the cable to adjust the idle, you were doing it wrong. Look up the PROPER way to do it.
Short version: start the car, let it warm up, unplug your IACV, use the big screw recessed into the corner of the TB to adjust the throttle to spec, turn car off, plug IACV back in, reset ECU, start car.
Never adjust idle with the stop screw on the throttle rotor. That shouldn't be fucked with.
Cool i will try everyones advice im still learning a lot working on cars ive never had so many problems till i started driving Hondas lol. Most of my 240s never gave me any issues at all and i never worried as much as i do now but i love this 97 CX Hatch andi hope i can fix this issue im also having issues with this crapzone alternator i put on last week.
And on the idle i didnt touch the little allen wrench bolt i just took some slack off the cable because it was having some slack so just tightened the cable wit the 12mm wrench i hope i did not mess anything up doing that i just figured it want supposed to be loose
Cool thanks guys, i guess tomorrow i better get started this Cx Hatch needs to get me me out of this hole i dug myself into
Well today i took the airbox off and looked to see if the iacv can come off easy and it doesnt look that hard and i peeked in the throttle body and it looks like a lot of build up and shiny oil or something lol.....I guess ill run some seafoam through the vacuum lines then take off the iacv....May have to get a aftermarket intake pipe,it would look a lot cleaner without the top mount airbox lol
I am now starting to think it has a mild headgasket leak....when i look in the overflow tank i see 2 or 3 medium to small size bubbles pop, not a bunch just like a constant 2 or 3 bubbles popping no foaming and sometime it rises sometimes its empty its weird,and one time i started the car with the radiator cap off not cold but warm and a little bit of coolant splashed out and i tried it again radiator cap off and it did not splash and on the 3rd time it splashed again,and it will rise up,i dont seem to be loosing coolant though if i am its very little almost not noticeable....i saw white smoke this morning on cold start it was kinda cold out also and it went away. and when i smell it it smells more like exhaust fumes and nothing sweet. The other day i drained the radiator and put fresh coolant in and i did not bleed but i dont think any air is in it the temp gauge does not over heat ever and when i grab the radiator hose its not burning hot. So i assume i have a small head gasket leak and that might be why my car is low idling on start ups and shaking but smooths out after like 4 or 5 seconds but sometimes it will idle low and stall so i rev it up a little before it stalls then the car runs perfect has all its power and smoothness after no hesitation at acceleration and no puffs of smoke at stop and go traffic....but i got some throttle cleaner im going to spray the throttle body and try and clean the iacv tomorrow hopfully.
If it is a bad head gasket then ill drive it gently and save up for a b20z swap i guess i hope it lasts untill January lol
It is official i have a bad head gasket the coolant in the overflow tank smells like exhaust fumes but no mixing of fluids yet and it doesnt over heat even idling for a long time and drives fine so i guess ill baby it and keep my shifts below 3k and pray it will last till January at least since my accord has a blown transmission and it is no longer drivable.....
Turned out to be an ignition coil and a dead plug wire on the 1997 ex. I bought a rich porter ignition coil off ebay for 20 bucks and 32 for new wires at Orilleys,I have now put close to 4,000 miles and no check engine light and everything runs great. I have gotten rid of the cx because my gf gave me her 1997 ex and i didnt want 2 civics,so on the 1997 cx i never figured out what was wrong. But im glad that nightmare is over
Apple395
21
06-22-2014 10:24 PM
