1996 Civic No power to Audio/Deck
Car: 1996 Civic w/ aftermarket deck
Deck is still working but it dies from time to time, Check all fuses already, Could it be the deck harness? What else should i check?
The Grumpiest
Re: 1996 Civic No power to Audio/Deck
Are the wires cut and spliced or is there an aftermarket harness installed? In either case you will probably need to pull the head unit and check all your connections.
well i just check all the connections and notice that the all black wire from the harness (not the deck harness the harness from the deck to the inside cabin) isnt connected to anything, can i just splice it to another all black (negative) wire?
WalkerGSR1
Audio / Security / Video
03-05-2007 10:36 AM
