Dumb Question
Re: Dumb Question (georgeseq)
jack the car up to get that wheel off the ground, grab the wheel on each side, try to move it in and out. if there is play, then you need to replace the tie rod.
Unceasing Measure
Re: Dumb Question (2redstars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2redstars »</TD></TR><TR><TD CLASS="quote">jack the car up to get that wheel off the ground, grab the wheel on each side, try to move it in and out. if there is play, then you need to replace the tie rod. </TD></TR></TABLE>
That's really not a good way to determine tie rod failure. Usually, if you can get play in the wheel without using the steering rack, it's the wheel bearing.
Look at your tie rods. If the stud is cocked at a funny angle and there's grease all over the place, it's likely done for. If you turn your wheel while driving and there's a lot of slop in the handling, you'll want to check it out. Take pictures and we'll let you know.
Re: Dumb Question (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Look at your tie rods. If the stud is cocked at a funny angle and there's grease all over the place, it's likely done for. If you turn your wheel while driving and there's a lot of slop in the handling, you'll want to check it out. Take pictures and we'll let you know.</TD></TR></TABLE>
thats basically what i just said. except your grabbing the wheel and feeling for slop. and by doing this you can see what has play, you can do the same for the upper and lower ball joint.
09egkid
08-06-2010 02:54 PM
unknown0001
09-22-2006 12:02 PM
