00 Civic - I want my Fuel gauge to drop to E with key off
Old 06-30-2015, 03:17 PM
Uzumymw's Avatar
Default 00 Civic - I want my Fuel gauge to drop to E with key off
Hello, within a few days I wonder if It possible to change a fuel gauge that it will works only when the ignition is ON?
I mean, ignition (key) off - fuel gauge falls down:
Next, ignition (key) on - gauge shows the value of fuel:
I hope that I clearly explained what I mean.
Old 06-30-2015, 06:39 PM
Former User's Avatar
Default re: 00 Civic - I want my Fuel gauge to drop to E with key off
What car? What mods? What gauge?
Old 07-01-2015, 12:49 AM
Uzumymw's Avatar
Sorry I forgot to write, Civic EJ6 '00, and gauge from canada civic '97 (looks like EDM gauge), but working dimmer on them
Old 07-01-2015, 05:59 AM
Assuming that the swapped gauge is not designed to drop to E with key off, the gauge is bad.
Old 07-01-2015, 08:43 AM
Uzumymw's Avatar
So I can't change it?
Old 07-01-2015, 09:25 AM
What do you mean by change? You can replace it.
Old 07-01-2015, 10:55 AM
Uzumymw's Avatar
I don't want to change the gauge, I want to improve it that the fuel gauge will be working as I wrote in 1 post:
Old 07-01-2015, 10:58 AM
Improve? Are you saying that your gauge isn't broken? If it is supposed to work like the USDM gauge, it is broken and you either need to replace it or live with it.
Old 07-01-2015, 11:08 AM
Uzumymw's Avatar
So in the USDM gauges after turning off the ignition the fuel gauge falls down?
Old 07-01-2015, 11:09 AM
No, it retains the reading.
Old 07-01-2015, 11:12 AM
Uzumymw's Avatar
I want to change it that after the ignition switched off, gauge will falls down (like in other cars or gauges in 7th generation of Civic). Is it possible?
Old 07-01-2015, 11:14 AM
Default Re: Fuel gauge Civic
You'll need to replace the gauge.
I edited your thread title to reflect the topic of your thread.
Old 07-01-2015, 11:16 AM
Uzumymw's Avatar
Default Re: 00 Civic - I want my Fuel gauge to drop to E with key off
There is no other way?
Old 07-01-2015, 11:19 AM
Not that I'm aware of. The gauge was designed to operate as it does.
Old 07-01-2015, 03:49 PM
Fish Twig
tony_2018's Avatar
Get an s2k gauge, falls to zero everytime you key off.
Old 07-01-2015, 10:14 PM
Needs to be About 20% Cooler
DieMaster's Avatar
My first thought is you could hook up a delay relay that will power the gauge itself (not the whole cluster) for X seconds to let the gauge fall to E and a normal relay that disconnects the fuel gauge sender from the gauge so it will go to E. U could acoplish the same thing with a couple small relays and a micro controller on a small 1" square board.
Old 07-02-2015, 07:14 AM
In theory, this^ would likely work, though the OP would need to figure out how exactly to accomplish it and then decide whether replacing the gauge with one that has the function built in is an easier and/or less expensive solution.
Old 07-06-2015, 03:13 AM
Oh look, I can change this
deschlong's Avatar
^ True. Both are viable options. Replacing the whole cluster, however, would likely not retain an OEM look. And a relay-based solution would also be difficult as the indicator is not as-built to drop precipitously as the OP likely wants (think how slow it creeps up after a fill-up).
Old 07-06-2015, 03:32 AM
Uzumymw's Avatar
If instead of the fuel gauge insert everything from the temperature gauge?
My 93 accord
Honda Civic (2001 - 2005)
05-19-2017 04:50 AM
maxwellmercer
10-20-2010 01:31 PM
b18 hatch mike
Mid-Atlantic (Sales)
01-01-2008 05:33 PM
*Boostwerks*
02-16-2004 07:25 PM
jasonb
03-29-2003 08:23 AM
Quick Reply: 00 Civic - I want my Fuel gauge to drop to E with key off
