00 Civic - I want my Fuel gauge to drop to E with key off
Hello, within a few days I wonder if It possible to change a fuel gauge that it will works only when the ignition is ON?
I mean, ignition (key) off - fuel gauge falls down:
Next, ignition (key) on - gauge shows the value of fuel:
I hope that I clearly explained what I mean.
re: 00 Civic - I want my Fuel gauge to drop to E with key off
Sorry I forgot to write, Civic EJ6 '00, and gauge from canada civic '97 (looks like EDM gauge), but working dimmer on them
Improve? Are you saying that your gauge isn't broken? If it is supposed to work like the USDM gauge, it is broken and you either need to replace it or live with it.
I want to change it that after the ignition switched off, gauge will falls down (like in other cars or gauges in 7th generation of Civic). Is it possible?
Needs to be About 20% Cooler
1 Post
Re: 00 Civic - I want my Fuel gauge to drop to E with key off
My first thought is you could hook up a delay relay that will power the gauge itself (not the whole cluster) for X seconds to let the gauge fall to E and a normal relay that disconnects the fuel gauge sender from the gauge so it will go to E. U could acoplish the same thing with a couple small relays and a micro controller on a small 1" square board.
Oh look, I can change this
^ True. Both are viable options. Replacing the whole cluster, however, would likely not retain an OEM look. And a relay-based solution would also be difficult as the indicator is not as-built to drop precipitously as the OP likely wants (think how slow it creeps up after a fill-up).
