~PPLLEESSSSSEEEE Help Me Wire my NOS Dry Kit!!~
Asking for a lil help here. The manuel says something about a fuel pressure safety switch. I don't have one and i don't think i need one. Any way whay i basically need is the wiring of the 2 solenoids. There are four wires 1 ground..2 go to the Hot side of the microswitch when it is ON. and then there is the last one. My best guess is to run it to the microswitch also. Help me out.
Thanks a bunch
me
Jeremy
Thanks a bunch
me
Jeremy
In The Garage
Re: ~PPLLEESSSSSEEEE Help Me Wire my NOS Dry Kit!!~ (JSutterEH2)
the last one is supposed to be run to a full throttle switch, and if i was you, id read up on nitrous before i did the install. do you have a fuel flow modifier/adj. fuel pressure regulator?? stock fuel + nitrous = BANG!!!!!
how do you like jonesborough?? im from knoxville. ever see the primered 98 gs-r fully built and turboed on bronze volk SE37Ks?? just wonderin....
[Modified by 22lbGS-R, 4:17 AM 1/14/2003]
Re: ~PPLLEESSSSSEEEE Help Me Wire my NOS Dry Kit!!~ (22lbGS-R)
ahh hell when i said microswitch i ment full throttle switch. doh. Any way. I hvae had nitrous before on this same car. I won't be needing anything else i will just be running the 50 shot that came with the kit for a while. The kit adjusts the fuel pressure with vacuum. Thats it...Jonesboorugh is coo
so jeremy, you are finally getting around to installing that kit after all. i wish i knew something about it so i could help you out, but good luck . BTW, did u ever get the wet jet for it?
Re: ~PPLLEESSSSSEEEE Help Me Wire my NOS Dry Kit!!~ (Simple)
ok..thanks guys..i guess i am the only one on here that has this kit. And if you did you wouldn't go check the location of 2 or 3 wires. Thanks a bunch.
I think my ZEX N20 brain took a shit on me, PLEASE HELP ME DIAGNOSE this PLEASE!!! (also some Q's on
CivicSiRracer69
07-19-2009 07:55 AM
Chris_
05-19-2003 12:20 PM
Chris_
05-15-2003 10:44 PM
