[FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics)
Old 08-27-2007, 04:36 PM
  #226
Sundown's Avatar
Default Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Yea whenever i do swaps (96-00) for people and they want to keep it legal (BAR in cali) everything has to be from an SI (mounts, linkage, etc). </TD></TR></TABLE>
oops didnt see he was from cali
Luserkid, would you happen to know any information on #25 bolt on that diagram? thread, size, if there is a similar one somewhere on the car, so forth?
Old 08-27-2007, 05:50 PM
  #227
Luserkid's Avatar
Default Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (Sundown)
There should be 2 #25s but that picture only shows 1. Its a 8mm x 1.25mm x 30mm i believe. Not sure on the lenght. But 8 x 1.25 is the thread pitch and size.
Old 09-21-2007, 07:38 PM
  #228
MKBrandao4's Avatar
Okay love the write up, I'm soon getting an Eg but its automatic deff should be a project car. My question is if i did buy a b18 motor from another car thats manual could i just take out the ecu, engine,tranny and the wirring harness. Instead of going through all the trouble soldering wires together. Probably a dumb question but was searching the site couldn't find an answer.
Old 09-22-2007, 09:31 AM
  #229
LadyCivic_ej8's Avatar
Default Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (MKBrandao4)
Dang!! I've been wondering what's involed in converting my Auto to Stick. Great info!!
Old 09-22-2007, 09:38 AM
  #230
97Ej6mike's Avatar
Cheers!
Old 09-24-2007, 10:32 AM
  #231
Sundown's Avatar
i used a less conventional method for removing the heat shield.......
Modified by Sundown at 11:45 AM 9/24/2007
Old 10-12-2007, 02:03 AM
  #232
xSKEETx's Avatar
Default Re: (Luserkid)
i was just wondering where ur shop is located..
im interested in doing the auto to manual swap..
directions please
thanx
http://profile.myspace.com/ind...15924
Old 11-06-2007, 03:28 PM
  #233
jdmeg6hatchy's Avatar
Default Re: (xSKEETx)
WOW! one of the best FAQs around!
Old 11-18-2007, 08:07 PM
  #234
ClikHonda's Avatar
bumppp
Old 11-19-2007, 06:21 PM
  #235
IW92's Avatar
Great FAQ write up
Old 12-01-2007, 07:21 PM
  #236
ChadB's Avatar
great write up.
Old 12-10-2007, 07:34 AM
  #237
Iceman05's Avatar
DO NOT forget the bolt that goes from the top of the clutch pedal assembly to the chassis... It is hard to see and you will miss it if you are not looking for it. I did not see it and only installed the two nuts that held the master cylinder/clutch assembly to the firewall. My pedal had so much flex that it never fully disengaged the clutch during shifts. It made the car unbearable to drive and caused 3 blown clutches, a transmission, and 8 months of my time. It is probably the most important single bolt in the whole conversion.
Old 12-10-2007, 09:09 AM
  #238
lowfast's Avatar
Nice write up
Old 12-22-2007, 03:01 PM
  #239
obligatory's Avatar
great guide, it's been of much use!
I am pretty much done gathering everything I need to do this swap on my 96' civic EX, however I am still not very clear on the whole Intake Manifold/Throttle Body issue.
Is it 100% absolutely necessary that I replace these when I swap?
Could someone please sum it up for me?
I've read the luser's full guide probably 3 times through and read the 10 pages of posts twice through.
I simply don't want to spend that much more money if I don't have to.
Also, here is my swaps project thread:
https://honda-tech.com/zerothread/2177326
Old 12-22-2007, 04:42 PM
  #240
Luserkid's Avatar
Default Re: (obligatory)
I am pretty sure this has been mentioned plenty of times but no you do not have to run a manual intake manifold. Manual TB you do however have to. For the auto manifold you would just need to drill 2 holes and tap another hole for the IAC.
Old 12-30-2007, 10:00 AM
  #241
obligatory's Avatar
a 99-00 ex IM would work for my 96 ex right?
Old 12-30-2007, 10:03 AM
  #242
Luserkid's Avatar
Default Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (obligatory)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obligatory &raquo;</TD></TR><TR><TD CLASS="quote">a 99-00 ex IM would work for my 96 ex right?</TD></TR></TABLE>
Just plug the injector air holes and your set.
Old 12-30-2007, 10:04 AM
  #243
sicones's Avatar
yes but the 4 air injection holes above each fuel injector needs to be blocked off, you can get it welded or use JB weld
/\/\/\ beat me to it
edit: if you respond to your pms I could possibly help you
Old 12-30-2007, 11:25 AM
  #244
obligatory's Avatar
Default Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (sicones)
awesome, this may not be so bad after all
I found one with everything on it for like 30 bucks and its local
Old 12-31-2007, 10:56 PM
  #245
obligatory's Avatar
Default Re: (Iceman05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iceman05 &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT forget the bolt that goes from the top of the clutch pedal assembly to the chassis... It is hard to see and you will miss it if you are not looking for it. I did not see it and only installed the two nuts that held the master cylinder/clutch assembly to the firewall. My pedal had so much flex that it never fully disengaged the clutch during shifts. It made the car unbearable to drive and caused 3 blown clutches, a transmission, and 8 months of my time. It is probably the most important single bolt in the whole conversion.</TD></TR></TABLE>
Alright, you've got my attention, but I only see the two master cylinder bolts on my clutch pedal bracket. Also cant tell much from this picture:
I'm half way through this swap, finishing up today hopefully, so if anyone could elaborate (size of bolt, anything really) that would be cool
Old 01-01-2008, 11:13 AM
  #246
Luserkid's Avatar
First picture thats circled there is a slot:
The bolt goes through there and into a threaded piece thats located in the circled area:
If you move the clutch pedal around when its in youll see it.
Old 01-02-2008, 02:43 PM
  #247
JDM_CRX_PLEASE's Avatar
so i think ive figured it out.. for my 97HX motor to work with my 00 DX chassi. i need a 99-00 HX,EX,or SI engine harness. and a obd2b-2a harness and plug up the HX ecu. and i should be set right? also are any of the 99-00 5 speed ex,si,or hx harness dizzy plug gonna be differ from the 97 hx dizzy? cause i mathed up my dx 00 AT harness and the plugs dont fit..
Old 01-02-2008, 05:06 PM
  #248
Luserkid's Avatar
Default Re: (JDM_CRX_PLEASE)
JDM_CRX: You want 99-00 HX harness, use your distributor from the pervious motor and your set. Make sure you have a 99-00 HX ecu.
Another thing you could do is still swap the dist and use your stock harness, wire in the extra plugs you need (VTEC, KS, EGR) and get a 99-00 HX ecu.
Old 01-02-2008, 09:04 PM
  #249
obligatory's Avatar
My project is now complete
I posted a thread about the cost, tools, and general tips of this conversion right here on h-t.
edit:
link was wrong
https://honda-tech.com/zerothread?id=2189516
Special thanks to luserkid for getting me started on this conversion!
Modified by obligatory at 10:17 AM 1/3/2008
Old 01-02-2008, 11:58 PM
  #250
so i cant use the 97 HX ecu? wouldnt it cost moreto buy a 99-00 ECU rather than gettin a jumpr harness?
Quick Reply: [FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics)
