***Trying to identify SOHC head Vtec or Non Vtec D15b***
Old 06-21-2007, 08:21 PM
headrec*'s Avatar
Default ***Trying to identify SOHC head Vtec or Non Vtec D15b***
Ok
I have a d15b block and some unknown head. Trying to find out what it is. It has a port for a vtec solenoid but it has been blocked off. I tried searching to find how to identify the head.
The only real number I found was pm38 unless I am looking in the wrong spot.
The plug wires are on the intake side of the valve cover which is leading me to believe its a non vtec head, BUT like I said it has a port for a vtec solenoid and its a d15b block which is the vtec bottom end.
Anyone????
Old 06-21-2007, 08:24 PM
94c1v1cex's Avatar
Default Re: ***Trying to identify SOHC head Vtec or Non Vtec D15b*** (headrec*)
there is also a d15b non vtec but if there is a port for the solenoid then it's most likely vtec...
Old 06-21-2007, 08:26 PM
headrec*'s Avatar
Well like I said it DEFINITELY has a port for the vtec....so...anyone else?
Old 06-21-2007, 08:29 PM
94eh2's Avatar
Default Re: (headrec*)
mostlikely it is vtec...
Old 06-21-2007, 08:33 PM
CapnKrunch's Avatar
Default Re: (305accord)
you can most likely identify by the plug wires. the vtec wires are diffrent than the non vtec ones as in the rubber that goes around the rings on the valve cover are smaller in diameter than the non vtec ones.
Old 06-21-2007, 08:42 PM
headrec*'s Avatar
Pic of block off plate
Pic of motor
Hope this helps
Old 06-21-2007, 08:51 PM
red ej's Avatar
so you wanna know if it originally had vtec? if it has the block off plate id say it did. or you can pull off the valve cover and check the # of lobes.
Old 06-21-2007, 08:52 PM
headrec*'s Avatar
I would like to know if I can wire up a vtec solenoid and possibly the ecu and have this bad boy with vtec haha.
Old 06-21-2007, 08:53 PM
red ej's Avatar
i think its possible go for it
highrev1987's Avatar
Default Re: ***Trying to identify SOHC head Vtec or Non Vtec D15b*** (red ej)
its not VTEC.
Old 06-21-2007, 08:56 PM
headrec*'s Avatar
Please someone give a reason why or tell me how to identify the head so I can tell for myself?
Old 06-21-2007, 08:58 PM
see the difference that is a sohc vtec head
LastGenEK's Avatar
man thats a tough one, personally it doesnt look vtech but isnt there different dizzys for a vtek and non vtek motors??????
Old 06-21-2007, 09:09 PM
headrec*'s Avatar
I notice the spark plugs are on the exhaust side but in my searching it said they sometimes have it on the intake side as well (obd II???) and I had the valve cover off to do valve adjustments and replace the gasket. I don't recall what it looked like under there. **** for brains i suppose ha.
Old 06-21-2007, 09:17 PM
how about now
Old 06-21-2007, 09:23 PM
Bejita's Avatar
Your motor is definately NOT A VTEC motor.....Sorry.
Old 06-21-2007, 10:08 PM
D Tranny Guru
Mista Bone's Avatar
Fuel pump block off plate
Old 06-21-2007, 11:06 PM
EJ2*Whitey's Avatar
Default Re: (Mista Bone)
Looks like a b7 head to me...
Old 06-22-2007, 10:36 AM
D Tranny Guru
Mista Bone's Avatar
B7's did have a mechanical fuel pump, but alas it is the same style head.
95accord0505
07-13-2011 08:56 AM
jivi
Honda Civic (2001 - 2005)
04-19-2007 06:28 PM
hatch808
06-02-2003 09:03 PM
big bentley
04-11-2002 07:21 AM
Quick Reply: ***Trying to identify SOHC head Vtec or Non Vtec D15b***
