**** 99 civic Hx Coupeż Idling problems ****
alright, my parents have a 99 civic coupe hx, motor is a D16y5 i belive...alright on to the problem. they tell me that every once in a while the check engine light will pop up and idle funny, (jump up and down from 1200 to 2000 rpm) without pushing/touching anything. but the car doesnt really do it when it is off, we frequently reset it by disconnecting the battery and hooking it back up, it will run fine for roughly 75-100 miles then the issue will occur once again, the only thing it really has as mods is an intake (bcuz we bought the car without one at all) if i remember right it was a intake temp code...but dont alot of people use their intakes even in the winter? and a little off topic but why isnt there a forum for 96- 00 civic's????
Re: **** 99 civic Hx Coupeż Idling problems **** (kc90hb)
Probably an idle air control valve......... If you don't want to spend the money on the parts guessing around. Simply wait for the light to pop on run over ti Honda or any trusted local shop and ask them to scan it for you. The ask how it should be fixed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kc90hb »</TD></TR><TR><TD CLASS="quote">...but dont alot of people use their intakes even in the winter?</TD></TR></TABLE>
I use my intake year round.
Wait till the code appears and find out what the code is by using the test jumper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kc90hb »</TD></TR><TR><TD CLASS="quote">why isnt there a forum for 96- 00 civic's???? </TD></TR></TABLE>
you are in it bud
2.B. Please do not make thread titles in all caps or with symbols that will attract attention. This steers users away from the other <U>(most likely more important) threads on the page.</U> <<<<<<<doubtful today
you are in it bud
Re: **** 99 civic Hx Coupeż Idling problems **** (civictildeath)
my bad about the title part, most people dont seem to look at my threads...dunno y
I use my intake year around, If its a CAI just watch out for rain puddles an everything should be ok.
try cleaning it with brake cleaner. 2 12mm bolts. careful not to overtighten them - they like to strip and take part of the IM with them.
i'd check grounding connections while i'm down there.
you tried swapping it out and it still acted up?
i'm not too sure about this one, but do you have a mass airflow sensor?
Re: **** 99 civic Hx Coupeż Idling problems **** (all stock)
Wish there was a way to completely get rid of the darn idle control valve. I cleaned mine a few months back and it started acting up within a few weeks. I replaced it and now is acting up again. Looks like it will need replacing again. I guess these darn things dont last more than 4-6 months.
Re: **** 99 civic Hx Coupeż Idling problems **** (RitcheyRch)
i use my intake on both my hondas year round right now it 5 degrees here dont matter maybe iac valve,or throttle pos. sencer or you'll have to check the code when the light comes on it will help narrow it down just do the jump wire and check the num. of times the light flashes.
Re: **** 99 civic Hx Coupeż Idling problems **** (gsrjeff)
I checked the code with my code reader and it is the IACV. 2nd one in about 4 months. There has to be a way to get rid of it.
GRNcivEX
10-03-2012 09:42 AM
sirdrew
01-08-2006 12:38 PM
