PCM Malfunction on 99 civic si coupe
Hello, has anyone else exprerienced problem with their 99 Civic.
I forgot the exact code, but when I had scanned it, the description said "PCM Malfunction". When I park the car for a couple hours in cold temperatures, it doesn't want to idle when i turn it on. Also, if you try to drive it, you can't go faster than 3000 rpm. Therefore, I have to hold the gas pedal until the car warms up. Then, I restart the car and it runs perfectly fine.
Does anyone have a solution, other than reprogramming or buying another computer.
Thanks,
Andrew.
Thanks,
Andrew.
///Nick
08-19-2011 06:12 AM
2000, 99, civic, cold, control, cotrol, honda, located, malfunction, malfunctioning, module, pcm, power, powertrain, si
